Nokia 6288 Cellular Phone Logo
Posted on Jan 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sking for pin to restore factory setting
Please help me
Anonymous
Level 3:
President:
  • Master 1,017 Answers
  • Posted on Jan 16, 2008
Anonymous
Master
Level 3:
President:
Answers
1017
Questions
0
Helped
974720
Points
2767
Reset your phone:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn phone on.
Keep them pressed until the reset screen appears.
Give it time to reset.
How do I reset the PIN Number on Samsung BD-H6500 Blue Ray DVD please?
Question edited for clarity and order, 'make model (what it is)' and toss in some CAPS.
Question moved from Cellphones to make model category.
https://www.manualslib.com/manual/834092/Samsung-Bd-H6500.html?page=50
Reset. ALL settings will be reset.
• When the factory default settings are restored, all stored user BD data will be deleted.
• factory default settings are restored, all stored user BD data will
be deleted.
• Press the button Eject (on top panel) for more than 5 seconds with no disc inside. The initialization message appears on the screen, and the player turns off automatically. When you turn your product on again, all the settings will be reset.
Don't use this unless absolutely necessary.
How to Reset a Samsung Blu-Ray Player - Support.com
Support.com https://www.techsolutions.support.com > how-to > ho...
1 Factory Reset · Make sure there is no disc in the player. · Press and hold the Eject button on the device for at least 8 seconds. · On the screen you will see a ...
I have a nokia n 81 8gb phone.how i will restore factory settings
Please enter *#7370# on your mobile . this will ask for factory settings reset. Please note that when you restore the factory settings, all your data in the phone might be erased so make sure you take a backup of the data and contacts before you perform a restore. You will also be asked for a security code. The default nokia core is 12345 but please make sure you enter the security code for you phone. Incase this doesnot work follow this.
Please Click the menu key and then go to Settings. In the settings menu, go to security settings. Here you can find the Restore Factory settings option. Please note that when you restore the factory settings, all your data in the phone might be erased so make sure you take a backup of the data and contacts before you perform a restore. You will also be asked for a security code. The default nokia core is 12345 but please make sure you enter the security code for you phone.
Thanks. Please rate if you find the solution helpful.
Help me please code reset for nokia 6103 IMEI: 352730014193854
IF YOU WANT TO RESTORE YOUR MOBILE'S SETTNG THEN GO TO SETTING OPTION AND SEARCH FOR RESTORE FACTORY SETTING OPTION. IT WILL ASK YOU FOR PIN THEN ENTER THE DEFAULT CODE (12345 OR 00000).
IF YOU HAVE CHANGED YOUR PIN THEN TRY THIS MASTER CODE 2712210654
THIS WILL DO FOR YOU
21helpful
4answers
Restore factory settings
HOW TO RESTORE FACTORY N72
18helpful
2answers
4helpful
I need a pin number to reset my phone.
hi,
try this which is default.
00000000
rate me if this helps
1helpful
Forgetten PIN code
The default PIN Code for restoring the factory settings is 12345.
Try with this .
incase if it doesnt work
*#7328748263373738# resets security code.
probably this must work .
2helpful
2answers
Pin unlocking code
you have to reset all codes on the phone back to factory setting go into security and restor factory setting it will explain in phone handbook how to get to this then for the password type in eight 0 the phone will then restart and say done
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
