Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
1. Manually turn on the component you want the remote to control
(TV, VCR, DVD, satellite receiver or cable box).
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
wish to program. The LED indicator light turns on and remains on. If
you release the component key any time during the Direct Code Entry
procedure, the LED indicator light blinks four times, and the process
is exited.
3. While holding down the component key, enter the four-digit code that
corresponds to your component’s brand. While you are pressing the
numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns
on. At this time, release the component key.If the LED indicator light
turns off, you have entered a valid code and have followed the correct
procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for
Direct Code Entry, the LED indicator light blinks four times when the
component key is released. This is an indication that a programming
error has occurred. In that case, repeat the Direct Code Entry process
from step 2 and try the next code listed.
