Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo Logo
Posted on Jan 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Top portion of screen blank
A block of the screen is blank. This black box covers a top portion of screen
  • blurabbit Jan 14, 2008
    First, the power went out, afterwards this showed up. I vaguely remember seeing this problem with a someone's tv many years ago, but I do not recall the solution. Could it be as simple as turning off the close-caption feature.
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Jan 14, 2008
Anonymous
Expert
Level 2:
Answers
83
Questions
Helped
27711
Points
137
Could be down to the tube in side the tv that is what create the picture
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
2helpful
A black box in the top left corner of the screen
Make sure that the PIP (Picture in picture) function is disabled.
Black box covering the top of the screen.
go into customer setting and turn off closed caption
2helpful
Black box on screen
Check your closed-captioning setting and make sure captioning is turned off (or set for captions if you really want them). You'll find it's set to "text" mode right now. The set is blanking out a portion of the screen to display text it never receives, and you'll only see this when you view a channel where captions are being broadcast. Most sets have a button on the remote for captions, and it's easy to switch modes without knowing it. Then you wind up with the mysterious black box.
If this helps you out, please take a moment to rate the solution. Thanks for asking here!
Black box blocks on certain programs
Check your closed-caption settings. You should find it's set for "text" right now. Turn it to "off" (or to "caption 1" if you want the captioning).
In text mode, the TV blanks out a portion of the screen to put up text that never shows up. You only notice on channels or programs where captioned programs are being broadcast. This is a common problem; on many remotes there's a single button to control captions and it's easy to hit it and change settings without realizing it.
Maytag electric dryer won't start
Hi!! remove the top base cover of the dryer not the timer portion..
2answers
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
Mitsubishi WS-65315
Could this be CC or Closed Caption set on Text? Try turning off
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
