The cruise on my wife's 2003 sport-trac started acting up last night. At times it would take and other times not. She said the dash light would flicker and then would either take and the light would stay on or it wouldnt and the light wouldnt. Today it would not take at all. It has about 155,000 miles on it. Sorry but that is all I have gotten from her so far. What is the most likely things to check first and work through. Thanks
First thing , knowing what all is involved in the cruise control system helps
Speed Control
The speed control system is designed to maintain vehicle speed between 48 and 200 km/h (30 and 125 mph).
Normally, when the brake pedal is applied, the speed control module deactivates the speed control system. Under increased brake pedal effort, the deactivator switch, a normally closed switch, will open and remove power to the speed control actuator clutch, releasing the throttle independently of the speed control module.
Principles of Operation
The brake pedal position (BPP) switch is normally closed to ground. When the brake pedal is applied with the speed control system engaged, the BPP switch closes (to battery voltage), putting the speed control in stand-by mode.
NOTE: A redundant brake deactivator (BPA) switch is provided as an additional safety feature.
NOTE: The speed control module is integral to the powertrain control module (PCM).
The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The inputs to the powertrain control module (PCM) required to operate the speed control system are the:
The inputs to the speed control actuator come from the powertrain control module (PCM).
The outputs of the speed control actuator go to the speed control cable controlled throttle position sensor.
Special Tool(s)
73III Automotive Meter
105-R0057 or equivalent
Worldwide Diagnostic System (WDS)
418-F224,
New Generation STAR (NGS) Tester
418-F052, or equivalent diagnostic tool with appropriate adapter cable
Inspection and Verification
Visual Inspection Chart
Mechanical
Electrical
NOTE: DTC P0703 and DTC P1572 must be repaired before any other DTC.
Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index
DTCs
Description
Source
Action
P0500
Vehicle Speed Error
PCM
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
P1565
Speed Control Command Switches High/Out of Range
PCM
Go To Pinpoint Test A .
P1566
Speed Control Command Switches Low/Out of Range
PCM
Go To Pinpoint Test B .
P1567
Speed Control Output Circuit
PCM
Go To Pinpoint Test C .
P1568
Speed Control Unable to Hold Speed
PCM
Go To Pinpoint Test D .
P1572
Brake On/Off Failure
PCM
Go To Pinpoint Test E .
P0703
Brake Switch Input Malfunction
PCM
IF thier are no codes go to the Symptom Chart
Symptom Chart
Condition
Possible Sources
Action
SOURCE: 2004 ford sport trac - cruise control no longer works
This problem is most times caused by an open circuit in the rotating contact under the steering wheel, this part is called the clock-spring contact, it supplies a connection to the airbag and steering wheel controls like the cruise, horn and radio controls. I would check the fuse as well to cover the bases, it is fuse #9 in the passenger compartment fuse box, it is a 7.5 AMP
SOURCE: 2005 Sport Trac Cruise Control does not engage
If you can please look under the hood and find the Air filter, and follow that all the way to a round metal part (Throttle body) If you can see it there will be a coil,and on that coid will extrude a curved plate with a cable(throttle cable) attached to it running all the way back inward toward the back of the engine, and next to that there should be a second cable (crusie control cable). This cable is pulled on when you engage the cruise control, by a black box next to the fuse box.
If the Cruise control cable is near by try to reattach it and if it is damaged then have your dealership or some one mechanically inclinded to replace the tip ( if plastic) or replace the cable.
If that didnt help please get back to me
SOURCE: 2003 XLT sport trac ford cruise control does not
Did you check the shut off switch on the brake pedal assembly?
SOURCE: 2003 Ford Sport Trac Cruise Control Sticking
I "HAD" the same problem but fixed it.
'03 Sport trac w/70,000 miles. Started around 60,000 mile mark with light flashing briefly, only engaging 1in 10 times. Also, I noticed slightly decreased gas mileage around the same time.
Cruise Control problem corrected itself when I replaced the spark plugs and wires. Owners manual reccomended replacing plugs and wires at 100K. Do yourself a favor and replace them early. They were very difficult to get out. I noticed arcing from wires to block and several areas of friction damage to insulation. Wrap new wires with sheathing and tie wraps to prevent friction problems in the future.
SOURCE: How to I disable the airbag on my 2004 Ford
Remove RCM fuse from dash panel fuse box. Fuse F2.10 10 amps. Turn key onfor 30 seconds and see that Air Bag light is lit. Now disconnect battery negative cable for 1 minute, leave disconnected while service is done. now the air bag is disabled. To repower the system turn key on, insert fuse. connect battery, now turn key off for 10 seconds, then turn key on and watch the air bag light. it should go on then after the air bag module is happy that everything is ok, it will turn off.
Testimonial: "Thanks so much for the response now I won't have to wait half a day for my truck at a dealership. Much appreciated!!!!!!"
