Here are the codes you posted along with the possible issues that may have caused each code to be triggered. It's possible the circuit these switches share has a problem that needs to be diagnosed.
It could well be a problem with the wiring or a problem with the connections between the switches and the Multiplex Control Unit, or possibly with the Multiplex Control Unit itself.
B1129
Driver Side Door Lock Knob Switch Signal Error
Faulty Driver Side Door Lock Knob Switch
Driver Side Door Lock Knob Switch harness is open or shorted
Driver Side Door Lock Knob Switch circuit poor electrical connection
Faulty Door Multiplex Control Unit
B2077
Right Power Sliding Door Remote Control Switch 1 Signal Error
Faulty Right Power Sliding Door Remote Control Switch 1
Right Power Sliding Door Remote Control Switch 1 harness is open or shorted
Right Power Sliding Door Remote Control Switch 1 circuit poor electrical connection
Faulty Right Power Sliding Door Control Unit
B2078
Right Power Sliding Door Remote Control Switch 2 Signal Error
Faulty Right Power Sliding Door Remote Control Switch 2
Right Power Sliding Door Remote Control Switch 2 harness is open or shorted
Right Power Sliding Door Remote Control Switch 2 circuit poor electrical connection Faulty Right Power Sliding Door Control Unit
B2079
Right Power Sliding Door Remote Control Switch 3 Signal Error
Faulty Right Power Sliding Door Remote Control Switch 3
Right Power Sliding Door Remote Control Switch 3 harness is open or shorted
Right Power Sliding Door Remote Control Switch 3 circuit poor electrical connection
Check driver side switch panel both sides control from switches,,,, both sides of dash with doors open there is a triangle area panel fuse on driver side and connectors for door electrics,, on passenger side the connectors for passenger side check connections..
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Open the door, left side above on off switch there is contact for door sensing switch, press that check carriage assm moving right side?.. *if yes insert small peace of paper in it, use it..But if you want to replace the cartridges remove the paper object.** if carriage assm not moving open the upper cover check the switch..
There are 4 doors that will cause the error. There are 2 on the right side of the printer. If you look closely, there is a white plastic switch on the right side of the doors. The toner door has a black plastic switch on the left side. Then there is the fuser access door on the other side of the printer that has a switch on the left side. Check the doors don't have any broken actuators that hit the switches. Check the switches by pushing on them manually.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer. hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
