Here is a link to the Philips user guide for the CD 130 / 135 which will enable you to change the melody , the handset volume, the message centre, and a whole lot more......enjoy !
http://www.p4c.philips.com/files/c/cd1302s_73/cd1302s_73_qsg_eng.pdf
http://www.p4c.philips.com/files/c/cd1353s_05/cd1353s_05_dfu_eng.pdf
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
