Question about Vtech DECT 6.0 Digital Cordless Phone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and nothing works. Everything else works great. Thankyou
  • mands2 May 31, 2011
    It is this one..http://www.amazon.com/dp/B0049A7MF8/ref=...
  • 1,116 Answers
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on May 31, 2011
  • 1 more comment
    Tried all the above. The ringer settings are leveled high.
  • Gale Todd May 31, 2011
    What model of phone is this? Is it the 6117?
    It looks like your phone needs servicing. you need to contact V-Tech. Here is their warranty service address:
    http://www.vtechphones.com/vtechphones/i...
    Also your manual is available from them from this site.
Anonymous
SOURCE:
My cordless phone a vtech 5.8GHz The ringer is turned off and I don't know what to do to turn the ringer back on.this is an older phone and i've misplaced my manual.,
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only direct you to enter it into the search box here to download a copy of the manual.
Jan 30, 2012 | Vtech 5.8GHz Analog Cordless Phone
How do i change/control ringer volume on presidian cordless 5.8 ghz?
While the phone is on standby, press vol/bell to hear the current ringer tone. Press vol/bell again while the tone is ringing to switch to the other ringer tone. The last ringer tone heard will be selected as the phone's ring tone setting.
Get the manual from: http://www.google.com/url?sa=t&source=web&cd=9&ved=0CFcQFjAI&url=http%3A%2F%2Frsk.imageg.net%2Fgraphics%2Fuc%2Frsk%2FSupport%2FProductManuals%2F4300257_PM_EN.pdf&rct=j&q=presidian%20cordless%20phone%205.8ghz%20user%27s%20guide&ei=wPopTpSkE8zPmAXFhuitDA&usg=AFQjCNFGoj6kwkI8m_Hhi9K1t49wifNP2g&cad=rja
Jul 22, 2011 | Lands Phones
We dont know how to turn the ringer down on the phone
The IA5864 doesn't have a ringer volume control but it does offer you a choice of several different ring styles, some quieter than others.
With the handset in idle (off) mode, press PROG. Press up/down until the screen displays "RINGER:" and the current setting. Press SELECT and you'll hear a sample of the ring. Press up/down to change the style. You'll hear a sample ring each time.
Full instructions are on page 9 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/606/UserManual/1644/ia5864_manual_bkm.pdf
Jul 09, 2011 | Vtech ia5864 Cordless Phone
How do I turn off the ringer to my vtech, model6032 telephone.
Ring volume
The handset ringer volume can be adjusted from five levels.
• Press MENU/SELECT to display menu when in idle mode.
• Press up arrow or down arrow to reach Setup HS. Press MENU/SELECT.
• Press up arrow or down arrow to reach Ring volume . Press MENU/SELECT.
• Press up arrow or down arrow to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
• The screen displays Stored and you'll hear a confirmation beep.
You can adjust the ringer volume by pressing VO L+/VOL- on the
telephone base when the telephone is ringing.
Jun 30, 2011 | Vtech 9009111 Cordless Phone
I have vtech 6.0.my fone bell is not ringing
Go to menu, call settings, ringer settings, ringer volume, and adjust. Do you have a dial tone?
Jun 08, 2011 | Vtech DECT 6.0 Digital Cordless Phone
CAN THIS PHONE RINGER BE CUT OFF
To cutoff ringer volume in Vtech cordless phones,you have to turn off the base ringer.
Handset:
program button->up/down" key to cycle until you see the Ringer selection->up/down" key(s) to cycle until the OFF selection
Base Ringer:
Menu->press menu until you hear "Base Ringer, to change base ringer press change"->PLAY/STOP button to save
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
No ringer, a symbol with a bell with a line throught it on screen. how do I correct it?
Look for a function or menu button.Press it,or you may need to hold it down.It will probably have all kinds of options available so you will have to cycle through it to set # of rings,ring on,ring volume etc.It should be there somewhere.If there is a directional looking button,you may have to use it to set some stuff.Press the original button again to cycle through.
Jul 22, 2010 | Vtech Cordless 6041 Phone
How to put phone so when phone rings, cannot hear it
Press Up or Down arrow to reach SETUP HS. Press MENU/SELECT.
Press Up or Down arrow to reach RING VOLUME. Press MENU/SELECT.
Press Down arrow all the way down, then Press MENU/SELECT to confirm.
A ringer off icon (Bell with a line through it) will be displayed on the screen.
Note: While the phone is ringing, you can temporarily silence the ringer by pressing OFF/CLEAR or MUTE/REMOVE. The next call will ring normally.
Rest of Manual details here: http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Jan 14, 2010 | Vtech Cordless 6041 Phone
My Vtech 5.8 cordless phone says ringer is off. How do I turn ringer back on?
press and hold menu button. Find ringer, push up button to change ring volume.
Nov 17, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
My vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
May 30, 2009 | Vtech 5867 Cordless Phone
Vtech DECT 6.0 Digital Cordless Phone Logo
724 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
