Yes you can repair it by changing the LCD or the display Strip.Generally the strip and the LCD can easily damage because these two components are easily damage.So, visit nearest nearest mobile repairing shop.Thanks for visiting fixya
Hi, to format your Nokia Mobile phone, please try this:
Restart phone while holding0+3+7+call(green) FORMAT.
For more Nokia keypad shortcut please visit the link below:
It is a software problem just try to renew your mobile software it'll get solved if mot then change your keypad strip before changing clean the strip connector it will get solved. If your an technician then only try it if your not then Please Visit your Nearest Nokai service center (Nokia care) they will do it perfectly.
Regards, Harish
// Feel free to vote this answer with 4 thumbs up //
No the Slider strip doesn't come separately because the strip is merged permanently to a circuit that has your earpiece ,light sensor,and front camera you cannot seperate it in any manner because the only unlockable part over there is the LCD screen .i would recommend you to get your phone serviced from nokia care only because the strip is the most important part in a slider .. even if you get a local strip installed from a local mobile repair center it wont last for a month ..even i had the same problem 4 months back ..because quality of the strip matters .......
Dear it is very easy but a little bit tricky to change its screen, but if have you have any experience of repairing or opening the mobile phone then it will be more easy for you. you just open the mobile phone carefully because it has basically two parts screen part and Keypad part so be attentive while opening. after open the phone you just put off the strip (Jack) of LCD from the keypad part then put in the new LCD strip on it. reassemble carefully, you have done now...
Thank you
You have to check that your LCD is connected to the buttons strip from inside of your phone by opening its front casing. If it is in the strip connector, then you ave to change your LCD as your LCD had been over to show any thing.
