20 Most Recent Nokia 6101 Cellular Phone Questions & Answers
Use Dct4, enter your imei and select Cingular, click the button it should then give you the unlock code. There is usually a list of codes, try the 7th one first, if that doesn't work thr 1st, then the 5th. For your phone select 6102b. This may or may not work, do a google search on Nokia Unlock.
Nokia 6101... | Answered on Apr 03, 2015
You can get the restriction code for your Nokia 6101 phone from WickedUnlock.com and remove the Network restriction from your phone easily.
Nokia 6101... | Answered on May 24, 2014
search your network manually.If it persist consult with a technician.
Nokia 6101... | Answered on May 14, 2014
You have to master reset your mobile.By using the codes, you can reset your mobile..I found free reset codes at Unlocking4free.com ..It's free service..Through this you can reset your mobile easily..
Nokia 6101... | Answered on Apr 08, 2014
its in setting
Nokia 6101... | Answered on Feb 25, 2014
gnat trap apple cider vinegar or any type of vinegar just add a fruit or something to attract insects put vinegar in a jar poke holes in the top so they can enter they are very attracted to the vinegar and wont leave the jar or any other contraption you make place it in a gnat populated area and throw jar away after you catch alot perferably more then one trap till you get all of those pesky things hope this helps
Nokia 6101... | Answered on Jan 20, 2014
To unlock your Nokia 2720 phone you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
Click here to unlock your Nokia 2720.
Note: don't share your IMEI number on free forums like this.
Nokia 6101... | Answered on Jun 12, 2013
Yes you can repair it by changing the LCD or the display Strip.Generally the strip and the LCD can easily damage because these two components are easily damage.So, visit nearest nearest mobile repairing shop.Thanks for visiting fixya
Nokia 6101... | Answered on Feb 02, 2013
My advice to you? is to look for a phone that has the same network service provider you use! I mean if you use a suncellular sim, then look for a friend who also use suncellular sim. Then call the customer service of your network provider for further assistance, then tell them what your problem. Im sure they will not hesitate to help you. Is this my solution/advice helpful to you? you can send me email at [email protected] Kindly rate this up! Thank you.
Nokia 6101... | Answered on Jan 26, 2013
you would have to go to your media settings and alert as reminders
Nokia 6101... | Answered on Dec 18, 2012
Hi restriction code are nothing but your Nokia 6101 mobile is locked to one network provider .Due to this they wont accept other network sim in it .To solve this you must unlock it ,code are the best solution to unlock it .To get code visit Wickedunlock.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Nokia 6101... | Answered on Nov 14, 2012
Hi restriction code are nothing that your nokia 6101 mobile is locked to one particular network provider .Due to this they wont accept other network sim in it .To solve this you must unlock it code are the best solution to unlock it .To get code visit Prounlocking.com here they ask you the country name and the network provider name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Nokia 6101... | Answered on Nov 12, 2012
You can get the Restriction code for Nokia 6101 model phone from the site Prounlocking.com and unlock it from service provider lock easily.
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nokia 6101... | Answered on Sep 01, 2012
Hi, You can get the unlock code for a Nokia 6101B from www.Classicunlocking.com at affordable cost with easy unlocking guide.
Nokia 6101... | Answered on Jul 28, 2012
Nokia 6101 Cellular Phone Logo
176 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
phone dropped from pocket now screen
  • Cell Phones
