This could also be a progaming problem. It just means that too many plays have been used. You just need to reset and the disc should play. If you do not have a manual, ask any dealer and they can walk you through it. It entails switching on the service switch and putting in a quick code. Then you will start from the beginning. For example, 9999, will entitle you to that many plays.
1. Turn your phone on and locate the Settings menu. "Settings," scroll to "Call" select "OK" to enter the menu.
2. Scroll down to "Call Reject" and select this option.
3. Select "Call Reject List" on the next menu. Enter the ten-digit number of the person that you wish to block and confirm your selection. That number will now be blocked from you phone.
If you are happy with the solution then please rate this answer.
1. Load a DivX® disc.
The data disc menu appears on the TV screen.
2. Press up or down to select the folder and press OK to open the folder.
3. Press up or down arrow to select a track/fi le.
4. Press OK to confi rm.
ok
