I tried to ajust the Clock, and sceen changed to "5Ab" and I could not go back at all
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models, you simply press and hold the "Clock" button for 5 seconds. On other models, you press and hold the "Stop/Time" and "Cancel" buttons down at the same time for 3 seconds. These instructions should be in your owner's manual.
If these instructions do not work for you, or if your model number is different than what you posted this question under, please post back with your correct information so that I may be able to assist you further. I hope this helps you.
