no files inside my flashdrive but when i check on properties,it show a lot of space has been usedno files inside my flashdrive but when i check on properties,it show a lot of space has been used
You can't post conmments that contain an email address.
Plug in the drive -go to my computer and find it right click and go properties - look for folder options -choose show hidden folders -- you will probably find a folder called( trash) delete it and you should get your space back
When the drive is plugged in, empty the recycle bin or trash can on the computer. It may still being seeing used space because the files are technically still there. they don't really go away till you empty that recycle bin.
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
If you manage to recover your files, I would recommend that you re-format the flashdrive to make sure that you are getting rid of the virus, then re-install your flashdrive software if you use it.
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
