1993 Honda Civic 4 Door Logo
Anonymous Posted on Nov 12, 2009
Need to locate Fuse for Horn; interior lights Fuse Box Cover
Anonymous
Level 3:
President:
  • Master 720 Answers
  • Posted on Nov 12, 2009
Anonymous
Master
Level 3:
President:
Answers
720
Questions
0
Helped
438462
Points
2330
On this model, the fuse block is located below the left side of the instrument panel, in front of the driver.
The Horn/Interior light fuse is usually the 10A one.
Cheers,
Horn not working is there another fuse box apart from the one under bonnet many thanks
Yes, some cars have an interior fuse box, often located on the drivers side between the door and dashboard. There will be a cover with a finger pull if it's there.
Does a 1992 accord 2.2 engine have horn and radio relays
In the fuse box under the hood or in a box behind glove box.
What position is the horn fuse located
It may be in your fuse box? Sometimes the fuse box cover will tell you which fuse does what, either interior or under the hood? To go further, I need year--make--model?
HOW DO I CHANGE THE HORN FUSE ON MY 1999 BUICK LESABRE
Jim, Remove passenger side kick panel to access the fuse box where horn fuse is located #3 fuse in your manual, box fairly high up under dash. Horn relay under hood/engine compartment fire wall.
Check the attached links,instruction and guides and a manual for your buick, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Interior Fuse Box Location 1990 1999 Buick LeSabre 1992 Buick LeSabre...
Troubleshooting broken Horn or fuse or relay GM Buick LeSabre 1994 1995...
http://pdfstream.manualsonline.com/8/81776d98-998a-493c-aac6-a5895c51d47b.pdf
Horn doesnt work Ricks Free Auto Repair Advice
1helpful
I need to find the location of the horn fuse ( horn is NOT listed on the inside of the fuse cover) and also location of the horn relay.
The horn relay is inside the glove box. There are 3 relays in there. They are the horn, fuel pump, and daytime running lights (in that order from left to right)
My car horn is stuck on (very loud) and I removed the fuse for the horn, but now my radio or interior lights dont work. What do i do?
was the radio and interior light working before you removed the fuse for the horn? In the process of removing the fuse for the horn, you must have mistakenly tempered with the fuse for the radio and interior light.
So I would suggest you go back to the fuse box and deep them in properly because the interior and radio fuse might not be contacting properly.
I hope this makes sense to you.
Good luck.
1helpful
4answers
Replace horn fuse in fuse panel of 1992 pontiac bonneville
Your fuse box is located on the driver side under the dash board. Up above where your brake and gas pedal are located. There should be a plastic cover that can be snapped off to reveal all of your fuses and on the inside of this plastic cover there should be a diagram of the fuses that are in use.
2000 LaSarbe interior lights do not work
take the cover off the fuse box .. it may display the location of individual fuses on the cover inside as most do.
1helpful
How do i replace the horn fuse in a 1994 Chevrolet Corsica
Fuse box located to left of steering column under dash. Fuse #11 15 amp fuse is for the horn, interior lights and door chime.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
