Not sure what you mean by a temp restart only time lights should all be lit is if you placed the unit into diagnostic. Lets go one of two ways if you hit the normal wash button it lights along with heated dry you hit start button it flashes and won't go solid you have an open door switch, if everything is off and start light continues to flash you have a stuck key on the keypad.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation. To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
When Control Lock is lit, all buttons are disabled. If you press
any pad while your dishwasher is locked, the light flashes
5 times. The dishwasher door can be opened while the
controls are locked.
To turn off Lock, press and hold Heated Dry for at least
3 seconds.
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on. The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and Salt lamps and a lit Rinse lamp indicates successful accessing of services mode Fault codes F00 Pots & Pans Lit F01 Sani Wash Lit F02 Normal Plus Lit F03 Normal Lit F04 Economy Lit F05 Rinse & Hold Lit F06 Pots & Pans Lit F07 Sani Wash Lit F08 Normal Plus Lit F09 Normal Lit Flashing
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
