I am haviing trouble getting windows media player to connect to the mp3 player through the USB port can you please help me.
Check and make sure you are plugging it into a 2.0 usb port. If you are I would try another cable to see if maybe you have a bad usb cable. If that does not work then you can check and see if loading the driver for your player on your computer and see if that fixes the issue. Here is how you can do that:
1. Look for the icon named "Computer" or "My Computer" and right click on it and select properties, this will open a window named "System Properties".
2. In the system properties windows click on the tab named "Hardware", and Select "Device Manager".
3. On this window you will see all the devices installed on your computer, look for the device not working properly (printer, dvd rom, keyboard, camera, mp3 player, etc), if there is a bigger problem, more likely you will see a cross by it, or an alert stating there is an issue with it.
4. Right click on the device you where having problems with and select uninstall, it will give you a confirmation, press OK
5. Once the device disappeared from the list, click on the menu bar icon that looks like a computer with a magnifying glass this will cause for the system to scan for any devices not registered and will force the re installation of the device.
