2001 Chevrolet Blazer Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2001 chevrolet blazer and need to get the airpump replaced in it i have heard that i also need to get the breather vent extention kit. But i do not know where the best placetoget these two items are can you help me?
Roger Foster
Level 3:
President:
  • Master 701 Answers
  • Posted on Oct 29, 2009
Roger Foster
Master
Level 3:
President:
Answers
701
Questions
Helped
437616
Points
3451
Hello jesspurvis: My name is Roger and I will help you. Their is a GM tech bulletin for this . The bulletin number is 04-06-04-015A. The bulletin gives part numbers for the extension kit you will need. The only place you can find the parts is from a GM dealer. I know of no aftermarket for the parts, Also to replace the air pump and extension kit. A lot of it is done from under the vehicle. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
I have a 2001 Chevy Blazer with 4.3 liter have to keep putting gas in throttle body for it to start.What might be the problem?
if your car starts after putting gas in throttle, means that you have no sufficient fuel feeding and one cause is the injection system not providing the need fuel, pressure regulator the second cause,or the fuel filter is blogged.
1helpful
Drivers door pin and bushings need replaced again.I am looking for after market repair kit not the Dorman kit that was rpreviously installed .
Chevy blazers are ******* bushings. You can get bushings at any autoparts store. The key to keepinng them in good shape is lubrication.
2001 blazer rich
check the engine breather pipes. if one of these is split this will cause a headache inducing smell while driving
if this helps let me know
cheers
mike
3helpful
What should the air intake breather look like on a 1996 chevy blazer
Hi there:
An air breather replaces the intake vent hose on your crankcase, which vents the spent gases inside your head out into the atmosphere instead of back into your intake track. This keeps your engine clean and in top condition. Aside from that, air breathers also improve the appearance of your engine bay.
Installation of an air breather is a simple process that takes minutes. Simply remove the hose on your crankcase and replace it with this breather. Most breathers come with a clamp already included.
For parts replacement visit this Air Breather brands: Chevrolet/1998_9999_Blazer Intakes Air Breathers
In the follow video, checkl 5:20 minute about location...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
I have 2004 blazer,after i drive it my gas take will pop.whats wrong?
Sounds like your getting a pressure problem in your tank. Try and find the tank breather pipe and see if it isn't clogged up. If it is then you need to remove the blockage. If the tank can't vent the gasses build up and bulge the tank.
1helpful
Does 2001 chevy blazer lt 4.3 have camber adjustments in the rear or does a kit have to be purchased
the rear is a solid axle so there is no adjustment and no way to install a camber kit.
2001 blazer air pump
Hi Gabriel_curr,
There are two air injectors on your blazer.
The air pump is located under the front bumper on the right hand side. It's about the size of a soft ball. If replaced, remember to get the breather vent extension kit. If you don't replace this, the pump will go out again due to water getting in the pump.
Hope I've helped, don't forget to rate.
Lazaruselite
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
