I inherited a pfaff 1469 from my mother. The manual says, "Plug in machine". I have the foot control with retracting power cord, but where is the main power cord to plug into the wall and back of machine? Is it stored in the machine somewhere?
If your Pfaff 1469 sewing machine needs a hand tug to get it running every time after pressing the foot pedal, it could be due to several reasons. Here are some steps you can take to service the machine:
Clean the machine: Dirt, lint, and debris can accumulate in the machine, causing it to jam or run slowly. Use a brush or vacuum cleaner to remove any debris from the machine.
Oil the machine: Lack of lubrication can cause the machine to run slowly or seize up. Use a good quality sewing machine oil to lubricate the machine according to the manufacturer's instructions.
Check the foot pedal: The issue could be with the foot pedal. Check for any loose or damaged wires, and ensure that the pedal is properly connected to the machine.
Adjust the tension: If the machine is not properly threaded or the tension is too tight, it can cause the machine to jam or run slowly. Check the threading and adjust the tension as needed.
Check the belt: If the belt is loose or damaged, it can cause the machine to run slowly or not at all. Check the belt and replace it if necessary.
Check the motor: If none of the above steps resolve the issue, it could be a problem with the motor. Check the motor and wiring for any damage, and consider having it serviced by a professional if needed.
It is important to follow the manufacturer's instructions when servicing your Pfaff 1469 sewing machine. If you are not comfortable servicing the machine yourself, consider taking it to a professional for repair.
Depends on a lot of things including the visual and physical condition of the machine, its features, how it's been maintained over the years, the accessories included, the desirability of the machine, and location of the machine. Best way to find out is check with a sewing repair shop or search for machines for sale or recently sold on the internet, ie eBay...
Um, it could be no power to your machine, I would suspect it is the power cord, plug or possibly an internal electrical issue. If the foot control failed, the machine's light should still work.
