My 1999 chevy tahoe is leaking antifreeze. I replaced the water pump and thermostat and it is still leaking. After further investigation it appears that the intake manifold gasket might be leaking at the front drivers side of the intake, but I am not positive. Is this a typical area where the intake manifold will leak?
It could but- check passenger side front where heater core line go into manifold right behind alternator the hose line is connected by a press clip into an alloy fitting this fitting gets eaten away by anti freeze and hose angle pulls back on fitting the part is $18 at dealer and is screwed into manifold use caution if ur r going to replace at very edge of aluminum manifold---and check ur water pump bolts the 2 longer ones should have a lock sealant on them they bolt in thru a water jacket
Mine is doing the same with 104,000 miles It is the driver side intake manifold
coolent is leaking out tgr top back pasenger side of my chevy silverado 1500 is it the intake manifold gasket
