Car Audio & Video Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a mtx thunder 81000d amp i need to know if i can bridge it
jorge daniel villagra
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 06, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
741
Points
7
Tengo un mtx 81000d necesito saver valores de unos componentes escribime danielvillagra_13hotmail.com
Anonymous
Level 3:
  • Master 655 Answers
  • Posted on Oct 23, 2009
Anonymous
Master
Level 3:
Answers
655
Questions
0
Helped
314483
Points
2081
Hello frank_sadach,
"Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
Hope this helps.
  • jorge daniel villagra
    jorge daniel villagra Mar 06, 2014
    necesito ayuda para un amplificador mtx 81000d danielvillagraguionbajoarrobahotmail.com
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
MTX 81000D amp doesnt work
Have you checked to make sure your sub is wired correctly to the amplifier?
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
1helpful
Hi, I have a MTX Thunder 81000D and there's something burned, it is the component with next to it the number d198, does anyone knows which one it is? THANX
D198 is a diode. It burns when the amp loses the chassis ground connection and the amp tries to ground through the RCA shield. If the amp is still working, it's better to leave that diode out of the circuit. That's what MTX did on later models.
My mtx 81000d amp is burned in a few different places.
Depending on whats wrong with it, bench fees to check it usually start at $45 and then they will tell you parts and labor. without knowing what burned up its hard to quote.
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
Carlos
i have a 81000d for sale for 250 dollars car money still in perfect condition i am pushing 3 12 inch alpine type r subs
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
