I have an MTX Thunder 81001 with 4 gauge power wire. Everything is wired right and the amp comes on but it is not pushing the subs. Could my power wire be too small? The subs are doing NOTHING.
First of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
Oct 19, 2013 | Car Audio & Video
Jul 18, 2010 | Infinity Reference 611a Car Audio...
May 19, 2010 | MTX Thunder 311D Car Audio Amplifier
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
Mar 21, 2010 | MTX Thunder 6000 T61044A Car Subwoofer
Jun 04, 2009 | MTX Thunder 2-Channel Amplifier 502 Car...
Mar 30, 2009 | Car Audio & Video
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
Sounds like your Remote wire is way too big. it should be 14 guage. It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires. you should have the power supply wires separate from the Audiop signal wiring. Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Oct 19, 2007 | Car Audio & Video
484 people viewed this question
Why wont my amp push out power to my subs
Mtx thunder 4501 mono block amp how to wire 2 subs to it
