Question about MTX Car Audio & Video
How do I Bridge MTX Thunder 404 400 watts into one channel
Posted by Jason sibilsky on
Kevin Jolicoeur
    New Friend:
  • 3 Answers
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Posted on Nov 25, 2016
5 Related Answers
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Posted on Oct 19, 2007
Anonymous
  • 86 Answers
SOURCE: Schematic for MTX Blue Thunder Pro 752 amplifier
hello ..try this ...www.eserviceinfo.com...takes a bit of working out how to get them .when you do .you have to download bitzipper (these are a rar file)...then adobe 8 ..bitzipper can convert to a pdf flie so you can read them...hope you have some luck
Posted on Feb 12, 2008
Anonymous
SOURCE: 4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Posted on Mar 09, 2008
alvinbga
Alvin Barnabas
  • 134 Answers
SOURCE: mtx blue thunder 752 pro
When you bridge amp they some time double in power output into a certain load. If the actual load of your speakers are lower than the required bridged load the out put of the amp will proportionally try to increase again. You have to match your loads to the specs of your amp. Use your manual to see what is required, then use ohms law, for adding resistors in series/parallel to make your speaker load match. For more info please reply.
Posted on Nov 22, 2008
Anonymous
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
What kind of amp should i get for my kenwood mids and highs
you should go for a 4 channel amp that has 500 watts and try to go for MTX
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Is it bridgeable
yes you can bridge this amp to one channel
here are the specs for the amp
  • stereo or bridged mono output
  • Tri-way capable (Tri-Way crossover required)
  • 100 watts x 2 at 2 ohms
  • 200 watts x 1 in bridged mode
  • requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
  • PWM MOSFET switching power supply
  • Intelligent Surface Mount Technology for cleaner sound and greater reliability
  • selectable 85 Hz high-pass/low-pass crossovers, 18 dB/octave
  • preamp outputs
  • speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
  • 9-3/4"W x 2-1/8"H x 9-3/4"D
  • Feb 06, 2010 | MTX Thunder 4202 Car Audio Amplifier
    How mant watts is the mtx 4002
    my guess is that it would be a 400 watt 2 channel wich means 200 watts per channel or you could prob bridge it to make a full 400 watts to one channel
    Nov 30, 2009 | MTX 4002 Car Audio Amplifier
    I have a mtx thunder 81000d amp i need to know if i can bridge it
    Hello frank_sadach,
    "Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
    Hope this helps.
    Oct 23, 2009 | Car Audio & Video
    Setting for...
    HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
    Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
    Picking the right amp.
    yes you could go with a 2 channel. You could alwayse bridge it.
    Jan 07, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
    Mar 08, 2008 | Car Audio & Video
    Car Audio & Video Logo
    449 people viewed this question
    Top MTX Car Audio & Video Experts
    Marvin
    Marvin
    Tom Chichester
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
