How do i reignite a worcester 24i combi boiler ?
I looked up this unit for you and found out it is a hot water system. She needs to get to the main gas valve to light the pilot. This unit has what is called a thermocouple on it that keeps the pilot on, even when the boiler shuts down. Its just a matter of lighting the pilot light. There should be a metal plate with the directions on it at the gas valve to lite it. You will have a knob, more then likely red or black in color on top of the valve. It will say on, off, and pilot. It should be in the on position now. Turn it to pilot. Have some matches with you and a flashlight if you can. You will need to look back into the burner area to where your pilot light will be. The thermocouple is a copper colored tubing that runs right back to the pilot, as it has to get hot from the pilot flame to work. To start, depending on how far back you have to reach with the match, you may need to use a piece of solid cardboard rolled up, a small piece to light it and reach in. Turn the knob to pilot. Now, push down on the knob and hold it down. This lets gas get back to the pilot, so you must keep it down and light it at the same time. Once it is lite, you have to hold it down for at least a minute. Slowly release it, very slow. The flame should then stay on. Once it is on, turn the gas knob to on. With the thermostat set to come on, it will fire up and heat the water. If the pilot will not stay lite after you hold it down for 1 minute, and keeps going out, the thermocouple will need to be replaced. It is the copper line that screws into the gas valve and goes back to the pilot. You can get them at any hardware store for around $6.00. Maybe you can help her install it. It is very simple to do. I believe the pilot just blew out and she will need to light it. Just follow what I have told you, and she will get it lite. Good Luck to you.
