Question about Reliance Natural Gas Water Heater Control
The red light on the water heater keeps flashing
Posted by milt_hart on
Douglas Jensen
  • 494 Answers
Attached to the water heater is a troubleshooting chart for your sequence light. 1 flash means..., 2 flashes means...., and so forth. Find the chart, count the flashes and see what it means and we'll go from there. Douglas
Posted on Sep 18, 2010
I have a valliant atmo gas water heater and no hot water just the red bulb flashing
Gas (natural or propane) water heaters require electrical power to make the igniter work. The most common source is two (2) D batteries. When the batteries become weak an visual alarm will be visible, such as a red blinking light. Try installing new batteries.
Oct 10, 2016 | Water Water Heaters
Flashing red light mean
copy following link to identify water heater gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 17, 2014 | Reliance Water Heaters
Water is cold and the light keeps flashing need to troubleshoot it
Light flashing while water is flowing means you have a bad control board. Needs to be replaced. They can be purchased online
Nov 23, 2013 | Bosch PowerStar AE115 Tankless Water...
My red light is flashing
Gas water heater?
Copy following link to troubleshoot be gas control valve:
Add comment and describe type and brand of water heater
Mar 29, 2013 | Bosch & Tankless LP Hot Water Heater
Should the red lights be flashing or be on steady
A solid light is what you actually want.
If you have a blinking light, the unit is unable to keep up with the flow of water.
Slowly turn on the hot water for your bathtub until the light starts to blink to find your limit. in other words your tankless heater is too small for your needs.
The 24 model is more for houses with showers or slower flow.
The 36 or higher model has 3 sets of heaters to be used with a bath, higher flow.
Jan 20, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
Reliance Natural Gas Water Heater Control  Logo
5,718 people viewed this question
Top Reliance Water Heaters Experts
john h
Muntejaya Ginting
Muntejaya Ginting
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
