Warm Up Catalyst Efficiency Bank 1 Below Threshold If you ran you car for a long period with it missing, then you probably damaged your catalytic converter.
This is for Evaporative Emmision Purge Solenoi Circuit.I would look for a broken wire going to this circuit.If you do not find any broken wires then the purge solenoid more than likely is faulty.
The check engine light will stay on until the problem is fixed or corrected. Scan the engine and get the trouble codes which will give you and idea of what is causing the problem. Auozone and some other part store will scan it for free.
P2088 Dodge ,That is a cam position actuator, Not a cam sensor, Cam actuator control the cam angle, If this is ****** or advanced you'll definetly get CK ENG LT 2032, 2032 is reporting the engine condition and CK engine light is on due to a logic check, The function check has been suspended and the ECM is reporting the logic which is the condition of the vehicle, The first code was correct, P2088 that is a function failure. If there is acces to a freeze frame it will show at what MPH the vehicle was going if it is less than 40mph you can be sure the cam actuator is not advancing. Leave 2032 alone trouble shoot P2088 that is the source
Electronic control module
(ECM) computer circuit
problems - faulty
programmable read-only
memory (PROM).
OR
(Transmission) Input or
output speed sensor -
circuit problems. (Speed
sensor signals do not
agree with with selected
gear range.)
OR
Torque converter clutch
(TCC) - TCC is
mechanically stuck on.
Vehicle anti-theft system
(VATS) problem.
OR
Transmission Temperature
Sensor (TTS) - short circuit
problem in sensor or
wiring.
OR
Transmission fluid
temperature high.
