Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry 8520 curve Imei Unlock Code .i hope this will help you :)
Good Luck.
Don't worry about it. it is very simple to Unlock your Blackberry 8520 by entering Imei Unlock Code . you can get your Mep Unlock Code for Blackberry 8520 by third party or your network provider.third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy Blackberry Imei Unlock Code from third party. they will charge little amount.i hope this will help you.
Hello Rahul, you can get blackberry curve 8520 unlock code for airtel network from your provider. Another option you can purchase blackberry unlock code online at third party sites on internet, so you can do it anytime and anywhere.
It's a clear and fully detailed guide on how to unlock a BlackBerry Bold 8520 :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
To unlock your Blackberry you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
Click here to unlock your Blackberry Curve
Note: don't share your IMEI number on free forums like this.
Hello
You can get the unlock code for free by calling the network provider.
Or you can buy the unlock code from third parties.
Just call 7070 from your mobile and ask for unlock code.
