Computers & Internet Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Harvesting crops when i harvest crops, I can highlight way ahead of the crops im harvesting. It takes a long time for my avitar to catch up. not good. Facebood wont remember my name or password either
Ekse
Level 3:
  • Master 13,435 Answers
  • Posted on Oct 12, 2009
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3985254
Points
38023
Sounds like your computer is way too old to run a website like facebook, get a new computer.
My cme506 sticks in harvest setting. what do I do?
If unit is not coming out of harvest it should try two more time and lock machine out. First look at at the bin full eyes this is what stops harvest when ice drops into bin. if eyes test good then replace the controller.
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Ice machine harvest two times and shut off
These unit time freeze time and harvest times and keeps track of them. If your freeze time exceeds 35 minutes or harvest time exceeds 3 minutes, it will place unit in lockout. The biggest cause for excessive time to harvest is the harvest valve not functioning properly, and undercharged unit or a dirty condenser. The most probable cause is a dirty condenser. Under charged units can be determined by checking compressor outlet temperature while running, it should be 150 to 190 degrees depending on atmospheric conditions present. If it is harvest valve, the downstream temperature will stay at or near compressor discharge temperature. It should cool down to ambient temperature in a few minutes after freeze cycle begins.
My 2nd farm has mostly vanished and all the crops and most everything has gone just leaving a load of grass. how do i get it back? Unimpressed!
You can recover that but by spending some cash. The easiest way to prevent from next time, you must harvest the crops on time.
Wont let me harvest crops
maybe they aren't ready yet or they are withered. Maybe you don't have the energy to harvest them.
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Catching the silver Fish in Harvest Moon Save The Homeland PS2
type this on your browser (http://www.gamefaqs.com/ps2/530597-harvest-moon-save-the-homeland/faqs/24470.it takes you directly to the faq.
1helpful
Hi and thank you very taking the time out for me, first of all i have been playing farmville for 3 weeks, when one night my husband logged out and i logged in to harvest my crops, and it would not load all...
Farmville is a "Flash" game, I would update your version of flash at this link. http://get.adobe.com/flashplayer/
Also, clear your "Temporary Internet Files" aka "Cache".
Zynga is known for their numerous bugs in games they make, this will happen often to you. Usually it is all on their end and will fix itself within a day or so.
Another thought to ponder. When you log into Farmville you are directed to a certain server....which there are many of. So it is very possible that the server for your location is messed up and the server for your Mom's location is in working order. There is nothing you can really do to remedy that.
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
