Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
Sce170a-1a wont harvest - Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
howard thompson
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Posted on Nov 20, 2014
2 Related Answers
Joe Palazola
  • 124 Answers
SOURCE: Scotsman cme 506ae-1a harvest to soon. Where is
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Posted on Dec 11, 2010
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: Scotman SCE170A 1A will not harvest and the cube
You have a problem with float valve. See page # 8
http://www.scotsman-ice.com/docs/uploaded/sct/manual/SCE17MAN.pdf
Posted on Sep 16, 2011
I have a Scotsman SCE170a-1a undercounter ice maker it only freezes in the center of the evaporator. Compressor , fan and water pump all work. I suspect the hot gas bypass valve.
no if the valve was open or part open the plate would be warm or hot to the touch and no ice would form, more likely low refrigerant charge or restriction of gas flow and also make sure condenser is very clean.
Oct 04, 2015 | Kitchen Appliances - Others
Sce170a 1b
Top switch is Manual harvest, Middle switch is Purge, Bottom switch is ON/OFF/CLEAN switch. Switch this one to on and it should start the machine.
Dec 08, 2013 | Scotsman Kitchen Appliances - Others
Water keeps running after harvest,water does not raise float on a sce170a why
If I remember, this model is equipped with a dump valve solenoid valve and is probably stuck open and needs to be replaced.
Apr 06, 2013 | Scotsman Ice Maker With Bin Cube Style...
The Cube Grid is loose on my Scotsman SCE170A-1A, What is the best way to repair?
Sorry cant be repaired The evaporator plate will need to be replaced with the plates loose like that it will cause the ice to hang up and not drop when in harvest. depending on how old the unit is it would be more affordable to replace the machine. coil cost 1800.00 labor 600.00, freon, dryer, 300.00.
Jun 13, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scottsman prodigy icemaker max harvest time codes-common causes.
my prodigy periodically flashes 2 which indicates slow harvest what does this mean?, is it common for time to time to flash 2, how do I correct it
Mar 14, 2012 | Scotsman Prodigy Air Cooled Cuber C0330SA...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
642 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
