Gateway FPD2275W LCD Monitor Logo
Posted on Dec 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help with Compaq MV5500 CRT 15 inch monitor
I have got a compaq presario with a MV5500 monitor. This monitor has got manual buttons on the front to adjust brightness, contrast etc. On pressing those buttons a blue panel appera from where you adjust contrast and brightness by pressing the + and - buttons.
Since the last few days this blue panel has been flashing on & off continuously even though I am not pressing any of the manual buttons.
Whats the problem??
The blue panel appears above all windows and is at max contrast. My monitor is other wise OK though. Please help. Thanks.
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Dec 26, 2007
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
46804
Points
292
Hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
I HAVE COMPAQ S510 WITH DIM DISPLAY ...I NEED SOLUTION?
It will cost $50 to $100 to trouble-shoot and repair any 15-inch monitor.
It will cost $20 to $40 to purchase a "pre-owned" 15-inch LCD monitor.
If will cost $50 to $100 to buy a new 17-inch LCD monitor.
Your money; your choice.
I have compaq tft5000 15" lcd monitor when we
It is broken. Replace it.
If you look online for a "previously-owned" 15-inch LCD monitor, expect to pay $20 to $30.
If you go to any "big-box" electronics store, you can buy a 19-inch LCD monitor for under $100.
Either way, it's much less expensive to REPLACE it
than it would be for a professional TV/video technician to try to trouble-shoot and REPAIR it.
1helpful
My compaq presario 900 won't turn on
1. Check if your battery is fully charge or if there is power in your Compaq Presario 900.
2. Check for defect in your power switch.
Compaq monitor 5500
To download the manual of your monitor, please click the link below:
Compaq MV5500 Manual
Unfortunately, there is no driver available for your monitor.
Thank you
Width out of screen compaq mv5500
Replace modulation diode & TIP122
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
1helpful
2answers
COMPAQ PRESARIO FX700
I'm having problems locating a manual. Compaq doesn't seem to support the model anymore. Reading a review online, It almost looks like Compaq had an Application control this instead of practical buttons on the front. Here's the review I read that talked about it -> http://www0.epinions.com/content_28050886276
Hope this helps a bit! Sorry I don't have much else, I've been digging for a few days now to find more.
Grains in the Screen
Can you give me the model number from the back of the monitor ? Or the "Service Tag" number if it has one
Compaq 9500 color monitor 19"
first off, its is NOT 3 years, old, new to you but not new
not in the slightest is it NEW> in fact 2002 monitor !!!! oops get ripped off by fibbing sellers, that it?
and it is bad.
NO PC stated.
NO OS stated
and no photos of bad, screen.
strike 3 you are out, like the 100000 post here like this,
no inputs, and expects magic answer from the blind, SSDD.
the name COMPAQ ended in 2013, 4 year ago.
most CRTS ended in 2013, started in 1981 with IBM MDA.
Monochrome monitors. eeks.
so why not buy a real LCD LED monitor 2010 and newer.
and join the 21st Century VACUUM FREE, and dangerous
19,000 volts free too (1kv per inch) it can kill you,
don't spill drinks in the top ok and live another day.
(PS; worked this from 1965 to 2010,) even NAVY PPI monitors huge. so know monitors well I do.
100% free and Zero steal email from you .
https://www.manualslib.com/manual/273744/Hp-Compaq-Cv5500.html
RTM all there is is this RTM and play with knobs.
What is so wrong here, is no PC stated.
monitors this old do not work on modern PC, unless you learn how to do that. (skill sets that)
step one set PC to 800x600, (screen reso)
then plug it and and pray the CRT brain works. still
that is all there is to it.
power on PC set to 800x600 reso
power on CRT.
push left select button (spoon fed)
see no signal on screen, means PC is dead. signals on vGA jack.
see out of frequency, message , see 800 above.
that book stinks btw.
lets find others.
MV9500 right, MV missing on your first post why?
the 9500 , no mV is here.
it does have OSD screen , push select button
https://www.manualslib.com/manual/30062/Compaq-7500.html?page=15#manual
degause it,
move screen L/R& UP/DN
and shapes, I call it trapezoid changes.
bright and contrast , no magic here all SOP,
max RESO on this old pig is.15yo
is 1024,x 768 60HZ
over that as most PC do now, this PIG GOES NUTS> fails.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
