Sansui VRDVD4005 DVD Player/VCR Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need code for sansui tv/vcr combo - Sansui VRDVD4005 DVD Player/VCR
Anonymous
Level 3:
  • Master 325 Answers
  • Posted on Oct 10, 2009
Anonymous
Master
Level 3:
Answers
325
Questions
0
Helped
184292
Points
1117
Sansui 0000, 0240, 0479 (for TV use 0463)
GIve these codes a go
Hope this helps you out.
Cheers Little Dish Fitter
2 Related Answers
Bob Citizen
  • 520 Answers
  • Posted on Oct 22, 2008
SOURCE: Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Anonymous
  • Posted on May 28, 2009
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
5helpful
I need a code for my remote control?
Hello
You hven't given any specification of the remote control you have. Yet I hereby send you universal remote codes for Sansui herewith.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit codes to check with are:
0135 0310.
Four digit code for Sansui TV/VCR cobo is:
0310
  1. .
What is the code for sansui home theater DVD from a universal remote Wizard 2
Ok I do not have a code specifically for what you mentioned yet in checking all the Sansui devices, there are not that many and some codes repeat; So I listed all that I have for Sansui's: TV's: 0135,0310,0394. VCR's: 0310,0376,0377,0394,0256,0967,0303. CD's: 0666,0704,0723,0734. DVD's: 0394,0967. TV/VCR combo: 0310. TV/DVD combo: 0394. DVD/VCR combo: 0394,0967.
You will note that the BOLD ones repeat for many devices, give those a try first.
1helpful
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Rcr311w codes for sansui tv/vcr combos
CLICK HERE for your user manual.
There are 4 ways to enter the code.
Thanks for using FixYa - A FixYa rating is appreciated!!
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
20helpful
4answers
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
