I think I inserted battery in wrong - now it is stuck and i cannot remove
Take out the 6 screws, 2 left, 2 right 2 bottom next to battery compartment. Carefully remove case back (separates at join of matt silver/chrome edge and lever apart. a tiny ribbon cable will still be attached, so don't be impatient and be really gentle. Once apart, the battery can be seen lying in the case and can easily be levered out with a plastic or wooden implement. - an ice-cream lolly stick would do it! Replacement is (careful) reversal of opening. - Mike N.
I had to use tweezers, which scratched up the battery a little bit. It took a lot of patience, but I finally got the battery out. A very poor design that the battery could even be inserted wrong!
The battery should still be removeable - have you tried to move it or turn camera so the the open chamber is facing down and tapping the camera
SOURCE: Battery inserted wrongly and now cannot remove
I did the same thing. Don't send it back. I used my fingernail (it hurt like hell), and then used a blunt end of a spoon. It doesn't break very easy, jsut don't dig in, cut it, or put force on that black plastic part.
SOURCE: Fugi Z10
buy a new battery matee, i did the same thing, i bought a replacement battery on ebay, works a treat and im guessing half the rice of what you would buy in stores. good luck!
i did that too.. help.. my battery is stuckk
i tried taking it out with tweezers but it still wont budge.
