I have a Waterway Executive. I need to remove the impeller. I don't see a place to put a wrench on the motor shaft to keep it from moving so I can turn the impeller. Is there a trick I need to know?
Im guessing ...
On the motors I maintain, I remove the back cover. There is a start cap (usually black) on the left side held in place with a clamp. Use a phillips to loosen the clamp. DONT TOUCH ANYTHING that looks like a terminal, and be careful of the centrifical switch on the end of the shaft. Move the cap out of the way. The shaft has two flats that just happen to be 1/2 inch, Put an end wrench on the flats and you j
will have no trouble removing the impeller.
I hope this helps you
Testimonial: "Thanks for the help"
On my waterway 56 4HP there is a small push in cap on the far end, pry that off and you will see the end of the shaft with a large slot for a screwdriver. Use that.
