Question about Waterway Spa Pump Executive 56 Frame 4hp Single Speed 2 1/2" Intake 2" Discharge
I have the waterway executive 56 spa pump (4HP). I am trying to find out how to remove the impellar in order to replace a leaky seal.
The impellor unscrews from the motor shaft.
On the other end of the motor shaft, you will find a slot which you can insert a large flat screwdriver, or an 'armature holding tool'. Once you have something to fit into that slot, you should be able to hold the shaft steady and unscrew the impellor from the shaft.
Sometimes they can be awkward to remove. You may need the armature holding tool and also a proper impellor removal tool too. It all depends on how tight it is and weather or not it's seized.
Good luck.
Ian Kime.
Posted on Apr 28, 2017
That impeller may have been pressed on; good luck.
Posted on Aug 23, 2009
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Jan 31, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Dec 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Sep 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Jun 11, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
Nov 12, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
543 people viewed this question
