I have removed the back from the watch but cannot reomve the battery.
Try if you can rotate that metal cover
It's just stuck and will need a gentle pry from the tip of a small knife blade to pop it up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Battery Replacement:
1. Unscrew and remove four screws on back
of watch. (Depending on your model, you may have to take the watch band
off. Also, you could simply remove 3 screws completely and one just
unscrew halfway so that you can pivot off the watch backing plate...
that's what I do.)
2. Remove Watch Backing Plate (or pivot off if you just unscrewed three and loosened one).
3.
Unscrew the three (or four, depending on your model) screws holding the
Battery Brace. (Or completely unscrew two while only loosening the
brace enough to pivot off. Don't worry about mixing these screws with
the Backing Plate ones, as these are noticeably smaller).
4. Peal the Battery off the undercarriage of the Battery Brace.
Once
you remove (or pivot off) the Battery Brace, you'll see the battery
stuck with a sticky tape-like material to it; merely "peal" off the
battery.
5. Get New Battery. The dead battery you took out of the
watch has numbers on the back. Bring it with you to a drug store (or
where ever you go for batteries) and get a battery with the same
numbers. A drug store will do, as most watch batteries are fairly
standard.
6. Replace Battery. Replace battery reverse of the way you took the dead one out.
7. Put it all Back Together.
BONUS:
As
soon as you replace the battery (stick it on the Battery Brace) and
screw the Battery Brace into its original seat, either quickly flip the
watch over and look at the read-out OR hit the reset switch (the reset
switch is a metal contact "finger" that can be pressed to touch another
piece of metal).
On the read-out you will see the watch go
through a Power On routine that it does the very first time it is
powered on. Check it out. It's pretty cool.
Note - Sometimes on these watches, replacing Batteries are big pain.So, make sure you do not screw anything while changing Battery.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Maybe I didn't describe my watch correctly. It is a Timex Ironman Triathlon chrono. The battery is covered by a delicate metal thing that I can't budge.
Not sure we are talking about the same thing. I'm not able to budge this metal cover with a knife for fear of snapping something off
I just got it loose. Once I get the correct replacement, will let you know if I need more help.
Thanks
I got it. Thanks
