SOURCE: nokia 5310 security code unlock
sir 12345 because that is the default code for nokia unless you changed it.
thank you for using fixya
CHARCOIS
SOURCE: Forgot nokia n70 pin code
Get your phone IMEI number which is a fifteen digits number located in the battery compartment of your phone.
Then Visit http://www.nokiamastercode.com
Input the imei number at the site to generate a master reset code which you input when you switch on your phone.
This enables you to reset your phone security code.
Rate this fixya. Good luck.
SOURCE: starting pin forgot for nokia 5310 Xpress music
The default PIN code of a Nokia mobile is 0000 (four zero).
Try with this. You may also refer the User Guide of the phone for the PIN code.
NOTE: If you Enter a incorrect PIN code three times then your SIM card will be block and then you require a PUK code to unlock SIM and Phone.
You will get the PUK code from your SIM card service provider (mobile network provider).
Good Luck!!!!!!!!!!!!!!!!!!!!!
