20 Most Recent
AT&T LG CU515 Cell Phone - Black Questions & Answers
LG AT&t SKU codes
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
I need to unlock my lg CU515
On the AT&T Network, to unlock the LG CU515, it’s pretty simple:
- Put a non AT&T or Cingular SIM in the phone; the phone display: Invalid Smart Chip
- Enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code*
- Device should say: Network Lock Deactivated
- Phone may automatically reboot
*The 16 digit code can be obtained by calling AT&T Technical
Support and given the representative the IMEI number. In exchange they
will give you the Subsidy Unlock Code.
Voice Mail
delete the speed dial number from the list or just master reset the phone
Unlock code nokia 5310b
You can get an unlock code for your Nokia 5310b mobile phone from
Classicunlocking.com .Here you have to specify the country name,the
current network provider and IMEI number of your mobile phone.Then you
can get an unlock code from them at reasonable cost and unlock it.
Shuts off while in use
you most likely have a virus i would call at&t and tell them you bought it refurbished and tell them ur problem and they have to help u
Htc puk code
My dear:Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly SolvedBut:Don't try to enter a PUK code without knowing the right one.You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device. So Please You Go to Service officeand Get the Duplicate Sim From Office OpraterSame Your No Problem will Solved
How to unlock security code for nokia 5130 c-2??
It depends... If you've forgot Security code of your
Nokia mobile phone,
use Security Mastercode instead.
type *#06# on the main screen it will tell your phone's IMEI code
then go to this site
http://nfader.su
type there your IMEI code it will generate your security mastercode.
Instructions
Hi Deborah!
First of all you need to activate the bluetooth on your phone, after that turn on your headset, now get in the bluetooth menu on your phone, select search for bluetooth items, your phone will find your headset and it will ask you if you want to connect to it, select yes.
Many headset have a code, that code is neede to connect to the phone. if your headset have one the code should be in the manual that came with the headset. If your headset dosent have or need a code it will connect to your phone as soon as the settings is done on the phone.
Good luck
Nic
