SOURCE: Sanyo CLT2054 compatibility w/inverter power.
you can use the inverter, however you may want to filter the AC input to the adapter, I made my own adapter for use when camping and no longer use the AC Adapter supplied.... With the inverter, you may have fading and flickering problems in the long run. Contact me for more information
SOURCE: SANYO CLT2054 WITH FADING SCREEN
I found an AC adapter for the Sanyo CLT2054 that works GREAT!!
The ebay dealer is cenyglobal, specify "Sanyo-Right-4Pin-12V5A"
AC Adapter. The CLT2054 TV has "2" different power plug hookups.
When you look at the 4-pin connector with the flat side UP,
for my TV, 12V is on the RIGHT 2 pins. On the other versions
12V is on the TOP 2 pins.
HOPE THIS HELPS!!
SOURCE: I have a CLT2054 but i missed the power cable
I found an AC adapter for the Sanyo CLT2054 on ebay that works GREAT!!
AC Adapter. Price is ONLY $14.99 + $4.99 shipping.
The problem is that the CLT2054 TV has "2" different power plug hookups.
When you look at the 4-pin connector with the flat side UP, for my TV, 12V is on the RIGHT 2 pins. On the other versions12V is on the TOP 2 pins.
HOPE THIS HELPS!!
SOURCE: I NEED A CORRECT POWER CORED FOR A SANYO CLT2054 FLAT PANEL T.V.
The ebay dealer is cenyglobal, specify "Sanyo-Right-4Pin-12V5A" AC Adapter. Price is ONLY $14.99 + $4.99 shipping.
The problem is that the CLT2054 TV has "2" different "4-pin" power plug hookups. When looking at the 4-pin connector with the FLAT side UP, for my TV, 12V is on the RIGHT 2 pins. On the other versions 12V is on the TOP 2 pins.
HOPE THIS HELPS!!
