Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
Anonymous Posted on Oct 06, 2009
Fujitsu Siemens Scaleo 600. No power to processor.
Plugged in, worked yesterday, not today! Dead, no lights, fan, nothing. Power lead swapped, still no good. Five years old. Any ideas please?
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 06, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
10810
Points
31
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Testimonial: "Very helpful thanks"
Anonymous
Level 3:
  • Master 558 Answers
  • Posted on Oct 07, 2009
Anonymous
Master
Level 3:
Answers
558
Questions
0
Helped
195978
Points
1466
Is there a light on the motherboard?do you have a voltage switch on the back next to the power plug?Make sure that switch is set to 115 volts and not 220. You can try this,remove the power cable from the computer hold the power button down for twenty seconds, replace the power plug and try again .If there is no light on the motherboard replace the power supply
Seimans scaleo will not turn off unless i turn off at power switch whenon i get nothing
try to remove unwated application starts with windw or at startup.
it will help you.
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
http://ts.fujitsu.com/support/downloads.html
type scaleo 600 for searh
you will be redirected to drivers download page
5helpful
2answers
I want to download sound drivers for my fujitsu siemens scaleo 600
on this page
type sclaleo 600 for searh
you will
be redirected
1helpful
Fujitsu siemens scaleo 600 desktop just keeps shutting down any ideas
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Succes.
Finding the videocard in a Fujitsu Siemens Scaleo 600 PC
firstly check the pci slot where your moniter you plug in it. and change the card.
ramesh
Scaleo 600
Are you still having the same problem?
On a computer an amber light is usually a "busy" light from when the hard drive is being accessed.
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
