Cars & Trucks Logo
Anonymous Posted on Oct 06, 2009
My 85 Corvette dash lights sometimes fade out completely. The next day they work fine. Is there a component I need to change? Thanks, Dave
Jonah Oneal
Level 3:
  • Chevrolet Master 14,092 Answers
  • Posted on Oct 06, 2009
Jonah Oneal
Chevrolet Master
Level 3:
Answers
14092
Questions
0
Helped
7242108
Points
44533
A POOR GROUND CAN CAUSE DASH TO FADE OUT OR THE CLUSTER IS WORN OUT.
1helpful
WHY DOSE MY DASH NOT LIGHT UP WHEN HEAD LIGHTS ON
There is usually a dimmer switch for the dash lights near the left side of the dash behind the steering wheel. Sometimes that can get bumped when you get in the car and turn the dash lights completely off.
1helpful
2answers
My audio radio does not receive radio stations. what could be the problem. All electrical components work just fine. cassette,CD player works fine but there is no band that will come in on the radio.
Is it a digital tuning? If it is does it auto search but just not find any stations? If this is the case then as J.D.Browning suggested it is an aerial problem! You said there are 2 aerials.....how are they connected to the radio?
2answers
I have a 1992 Corvette Roadster and at night the dash lites dim to completely dark, just the dash lights allelse is fine, I have replaced the sunload sensor on the dash board by the windshield and the...
I don't know about the system, but it would seem like it is working in reverse have you checked to see if some how the wires are switched around.
3helpful
3answers
Need to remove ECM out of my 1985 Corvette
well your in luck i just removed mine today lol. there are 5 1/4 inch screws on the bottom side of the dash on the passenger side of the car remove them pull the plastic cover down and disconnect the light mounted on the piecce you just removed next make sure your battery is disconnected cause it may fry it if power is connected. Next you will need a 10mm look straight up you will see the box it is aluminum with 2 wire harness attached. There is a metal clip holding it attached pull it back and un hook the harness then it will slide right out.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
