How strange.Do you mean a pulsating in the front brake lever.If so you've got a warped front brake disc.As you apply pressure,the spinning disc is causing the pads>pistons>brake fluid to pulsate causing you to eventurly feel it through the brake lever.Put that beast on a centre stand with the front wheel off the ground ,HK.Look straight down the bike from head to tail,concerntating on the discs.Can ya see it now.????.Check your rear disc while your there and disc bolts for tightness. Best of luck HK.PS.Please leave feedback if i've helped. Tabby..OZ.
