It's probably a browser or windows error if using IE - try using firefox or a different browser. Yoville also has occasional loading problems that generally get fixed fairly quickly. Stack overflow means the program has run out of memory space to store
parameters to - the solution to this would be to clear your browser and try login again. ( Internet options for IE or clear private data on firefox), then restart your windows. It also is possibly a java script error - you can update java for IE at http://www.java.com/en/download/index.jsp
To fix IE6, usually there is a check box in add/remove programs, windows components, uncheck it, then recheck it and it will install IE again. If using IE6SP1, it will possibly be listed as a program in add/remove programs, simply click uninstall and it will then offer a repair or restore option, use repair. Restart is required. If using IE8, try going back to IE7, uninstalling will revert back to the 7 version. The 7 version works far better than 8. You might also try updating your flash player if the problem persists.
