2004 BMW 3 Series Logo
Anonymous Posted on Oct 02, 2009
How do you replace an air filter on a bmw 320d 2004 car
ZJ Limited
Level 3:
  • BMW Master 17,989 Answers
  • Posted on Oct 02, 2009
ZJ Limited
BMW Master
Level 3:
Answers
17989
Questions
0
Helped
14459366
Points
60858
Maybe this guide can help you like a reference guide: Change Air Filter (with pics).
I hope help you (remember rated this help). Good luck.
Testimonial: "super informative guide."
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2222
Points
Where is my air filter on my bmw 320d
Anonymous
Level 3:
  • Master 832 Answers
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
307720
Points
2315
Open the car hood, and look for the big rounded housing of the air filter. Unscrew the nut holding the top
cover. Unlock the clips holding the cover. Now, you can take the old air filter element, and put in the replacement. Replace the cover, cliplock, and the nut.
nd you are done.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2222
Points
Where can i find a english service manual for my bmw 320d year 2001
BMW 2004 320D No crank No Start Alarm permanatlly off.?
Quite often people forget to attach the ground cable that goes under a bell housing bolt , check there first.
Hi it seems like key is not responding. Its been immobilised.
you need to get some one down to get the key to be read by the car. Possibly need the car key reprogram
My 2004 bmw 320d touring white smokes when idle,and realy white smokes when driving.runs fine no loss of power.
Coolant is getting into one of the cylinders of engine , head gasket , a crack in the cylinder head or engine block !
Bmw diesel wont start
I'm guessing that you got an air lock in your fuel system as a result of your changing the fuel filter... I certainly don't know about a BMW diesel, but in most semi-truck engines, there is a priming pump just for the purpose of getting the air out ... and the fuel into.... the fuel system. I've even been known to fill the filters with diesel fuel before screwing them onto the base.. This is risky because of the possibility of allowing some foreign, unfiltered debris to get into your pump and/or injectors, just because of your putting unfiltered fuel into your filter... Check and see if there is some kind of priming pump close to the filter. Also, a possibility is that you may have an electric fuel pump.... as to where all you may need to do is loosen a fuel fitting on the pressure side of the pump and filter.... and allow the electric pump to purge the system of air.. I confess to my lack of knowledge on your BMW.... but, I do have some basic understanding of most diesel systems... Good luck..
WHERE IS THE FILTER LOCATED ON A BMW 320D
fuel filter or air filter? Cabin filter? Fuel filter will be under drivers side door near drive axle on left side of engine. Or by gas tank.
BMW 320D won't start
well the battery may have enough voltage and power for the lights but not enough to trigger the starter solenoid...
have your battery charged...
How do I change the Air Filter on a BMW 320d ?
very easy open house remove old air filter, vacuum out housing and replace with new filter....should take about 5 minutes...
1helpful
Bmw 320d engine shaking
You have blown the oil rings.
Air Conditioning on BMW 3 Series 2003
On this vehicle if the service history is up to date the microfilter would have been changed no more than 15000 miles ago. You may need the help from a garage to check to make sure that the air con system is fully charged, if so it may be the heater control panel it's self that may be at fault. It may be worth a visit to a local specalist or dealer to get the fault memories read but ask for a fixed quote for diagnosis before hand. hope this may be of help.
change the cabin filter will get rid of the smell however for cold ac you will need to recharge the ac and have a black light test in 5 days or less after it was recharged. then they would spot for a leak in the ac system
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
