Pioneer VSX-815-K Receiver Logo
Posted on Oct 02, 2009
Doesn't turn on
My pioneer VSX receiver doesn't turn on. I checked fuses and they are good. Any other suggestions? Power supply maybe? Is it worth it to replace the power supply or just buy a new receiver?
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on May 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
6459
Points
19
Does it have the blue flashing light on the power button?
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
4helpful
My pioneer vsx-519V-k amp won't turn on. Just bought it about 4 months ago. we were using it with music and a microphone when it conked out and won't turn on anymore. Have checked the power source, the...
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Fuse on a Pioneer receiver?
yeah it is located in the power supply from where the power cord is attached.good luck.
3helpful
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
2helpful
Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
