SOURCE: Slave Flash
I'm guessing you're talking about a wireless connection...
Unfortunately, the 430EX can only act as a slave. You'll need one of the following to act as a master control unit: 550EX, 580EX, 508EX II or the ST-E2 transmitter :-(
Matt
SOURCE: Can the Canon speedlite 430EX be the slave to the 550EX speedlite
Most any slave light will work I use a old vivitar flash with a slave module in the cord to camera outlet woks gook for a fill light. helix camera .com ritz camera. or ebay don't digital flashes a little different than strobes i played with the settings until i got the desired lightng I wanted., if your camera has a hot shoe you can get a slave to fire an external flash with it.hope i helped
SOURCE: Trigger a Speedlite 430EX II with a studio flash
SOURCE: Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
SOURCE: aaaaaaaaflash not firing with fresh batteries
Top cover is not communicate with external flash you need to replace top cover and try flash it should work
