It the CD tray which is at fault. Now-a-days the entire tray and the gears which are made from plastic(HDPE). For opening the tray the moment you touch the ope/eject button the same gears a fly when is pushed rotate a plastic gear which starts the process. However since this get locked by aa lever which in turn is also for ejecting the tray. This 2-3 plastic gears have got worn out unevenly resulting in the tray is hitting the last position and the rebound force is enough to dislodge the catch lever attached to the eject button.However this player is expensive and there worth a try to repair it. If a couple of these gears if replaced, will be able to repair the tray function then give it a try. However select an authorized service center since they will be bound to give you a service warranty of at least 6 months................sodeep
i was djing at a night club and there was a little bit of crown and coke spilled on the top of it. i...
(More)
i was djing at a night club and there was a little bit of crown and coke spilled on the top of it. i cleaned it off and it worked fine, i thought it was no big deal and then the next night when i started to warm up i noticed that it would play fine but the turntable has a lag on it when you move it like as if the top white part with the three holes in it to lock it when you recive it in shiping was sticking to the bottom part. as if it needed some wd-40. would cilicone spay help??
Hi, I've just bought a used Technics HD81 system and i'm running my tv through it, it worked perfect...
(More)
Hi, I've just bought a used Technics HD81 system and i'm running my tv through it, it worked perfect for around 30 mins and then just threw a wobbley. the system changed to CD on its own and then kept skipping through the cd's, flicking random selection on and off, same with repeat and randomly played songs without me touching anything, the system was then jammed on the CD selection (it wouldn't change to radio aux or tape) but i couldn't open the CD tray, no matter what button i hit it just kept switching the random play on and off- even if i push a buton on the tape deck. Have you any idea whats wrong with it please. Regards Brian
It will spin the circular bed that holds all 5 CDs, then randomly stop to begin a CD, but before it...
(More)
It will spin the circular bed that holds all 5 CDs, then randomly stop to begin a CD, but before it actually starts a track, it stops and again starts spinning the circular bed to repeat this entire process, never to play a track. It doesn't seem to matter which buttons I touch,the player has a mind of its own and eventually after many frustrating minutes will stop and begin playing an entire CD.
My Technics SL-PD8 5-disc player continuously makes a whirring sound and the tray will not open. I...
(More)
My Technics SL-PD8 5-disc player continuously makes a whirring sound and the tray will not open. I had a look inside and it appears to be something wrong with the disc-reading mechanism. Please help!
