Turn off the computer and disconnect the power cable from the electrical outlet.
Remove the computer cover.
Locate the 2-pin password connector (PSWD) on the system board.
Remove the 2-pin jumper plug.
Locate the 2-pin CMOS jumper (RTCRST) on the system board.
Move the 2-pin jumper plug from the password jumper to pins into the CMOS jumper.
Plug in AC power to the system and wait ten seconds for the CMOS to clear.
Move the 2-pin jumper plug back to the password jumper.
Replace the computer cover.
Connect your computer and devices to electrical outlets, and turn them on.
Location of the RTCRST Jumper will vary by platform and form factor. For more information about the jumper locations refer to the system service manuals located at www.dell.com/support/manuals
To remove Bios security password login in Bios then go to the security tab and remove the password.
Or the mother board jumper reseting can remove the password of the Bios without Bios login.
I believe that you need to set up the CMOS jumpers inside the main circuit board. For details click on this link (Click Me)
1. Look for 3 pin CMOS clip that says CLR CMOS on the mainboard
2. Take out the jumpers from 1 and 2
3. Put it in jumpers 2 and 3 and wait for 5 seconds
4. Put it back to jumpers 1 and 2
Figure 1. Schematic Diagram of Main Board Dimension 4700
Assuming this is a desktop and when you say you can't access it because of a password, there is a solution. -Unplug your computer -Press the power button to release all power in the capacitors -Open up the case -Ground yourself by touching the metal case but not the board. -Look towards the edge of the mother board, there is usually a button or a jumper (a set of two pins with a black piece of plastic across them) -Press the button or remove the jumper -Plug the computer in and start it
You should be able to access the BIOS now. Once you finish, replace the jumper if needed and you are clear. You might want to reset the password in the BIOS while you are in there though.
