I 'inherited' a Bell+Howell tv model number GNB127 1108 and I can't seem to get the ''mode'' on the tv to actually go to tv. It goes to S-VHS and VCR/AUX but I can't get the regular tv to show up. Help.
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
SOURCE: AUX to normal channels!
Have you done a hard reset? (Unplug the tv for a couple of hours, then power it up again).
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
SOURCE: My Bell Howell TV has suddenly decided to go into Demo Mode. ...
Press the volume up and volume down buttons at the same time.
