20 Most Recent Zenith SY2068DT TV Questions & Answers
Hello
Three digit remote codes for Zenith TV are:-
000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153/ 0016/ 0017/ 0092
Four digit remote code for Zenith TV are:-
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Zenith SY2068DT... | Answered on Nov 19, 2010
The picture tubes in Zenith sets (I assume it's a Zenith since you posted this with a Zenith heading, although it's also true for any set this old) were only expected to last around 7 years. Your description makes it sound like you are missing green, or that the green is just way low. This is a common sign of a bad picture tube. There are other possible causes, but tube failure is the most likely. The low replacement cost for small TV sets makes repairing this one uneconomical.
Get rid of the set and treat yourself to a new one.
Zenith SY2068DT... | Answered on Jan 28, 2010
Yes. But U must purchase an adapter. Try radio shack or circut city.
good luck--------------------------tomtaso
Zenith SY2068DT... | Answered on Dec 01, 2007
Not available. All scam sites
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=ZQjzXOHIDoHu_QaijLTgDQ&q=zenith+z711b+manual
Contact Zenith direct
Zenith Electronics LLC
2000 Millbrook Drive
Lincolnshire, Illinois 60069
(847) 941-8000
Licensing
Jack Kail, jack.kail@zenith.com
Broadcasting Standards and Technologies
John Taylor, john.taylor@zenith.com
Media/Press Inquiries
Kim Regillio, kim.regillio@lge.com
Consumer Inquiries
Zenith/LG Customer Service, 800-243-0000
Click here for online Zenith customer service support
https://www.zenith.com/contact-us-2
Zenith Televison... | Answered on Jun 01, 2019
Check input or source if ok check audio see if speakers on
Zenith Televison... | Answered on Apr 03, 2019
If the fans aren't running, that is your problem. The unit has overheat protection and is switching off to protect itself.
2007 it says, time for a new one. Plasma is old technology.
Zenith Televison... | Answered on Mar 27, 2019
Google (zenith)(ZDA-510)(manual) without parens.
Zenith Televison... | Answered on Jan 05, 2019
Ebay has a broken model but said to include instructions for $5.00
Zenith Televison... | Answered on Dec 12, 2018
Televison & Video Logo
Popular Tags
3 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
colors going bad tv
  • Televison & Video
