Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. [email protected]..
Hello. Yes, you do need power to open the disc door. When you slide the disc cover open switch, you should hear the little musical sound, and then the "preparing to open cover" appears in the lcd display. Then the door opens automatically. As for charging the corder, you can get a new ac charger for 25 bucks on Ebay. Sony uses a special plug that is inserted. If you want to go the cheaper route, I saw mobile *battery* chargers for your unit(not to be used as camcorder power supplies) as inexpensive as 8 bucks...most were 10 dollars and up...the input voltage/current to the cam is 12v @ 500ma. However, the fact that the connector isn't the generic "cylinder" shaped power connector makes purchasing a compatable power source a necessity. ---Rick
Hi FixYa.
My cam corder is model number DCR-PC9 not DCR-TRV525
dileep007 tried to help me was not successful
I have always used DVM60 casset Willappreciate help to solve the problem. Sincerely
Mark Kaufman
Most often, in this case, the locking relay has failed. Sony has an improved part for this. It requires a Sony qualified servicer. I have replaced them before.
Good luck,
magic seadog
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down.
The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it.
Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
