20 Most Recent Hitachi DZ-MV350A DVD Camcorder Questions & Answers
Well Im going through the same thing and no one can seem to figure out what is going on. Ive tried all sorts of disc including a DVD-RAM Video 60 and Im still getting the same Error #2881 Code.
Hitachi... | Answered on Feb 13, 2019
Your best bet is to use the drivers from the CD.
To do this on windows 7, you'll need to use compatibility mode.
Browse to the contents of the cd in windows explorer. Right click on the driver installer file, and select "properties".
Select the "compatibility" tab from the properties window, and select "windows xp sp3" from the drop down menu. Also tick the "run as administrator" on the bottom.
I did this with my own hitachi DZ_MV350A and it worked just fine.
Hitachi... | Answered on Feb 01, 2013
You can view it through the windows media player. Open my computer, find the file in your dvd drive. Right click and select open with windows media player.
To do any editing you will need to convert it from a vro file to mpeg
Hitachi... | Answered on Dec 19, 2011
Improve the Fixya.com experience for everyone by voting!
Click on the following link and download -- FREE -- user manual for your Hitachi DZ-MV350A. Hitachi Manual Download
All the best,
Ben
Hitachi... | Answered on Jul 13, 2011
You can download copy of the user manual for this device from this link, just click HERE.
Was it recently dropped or bumped in any way? The focus and zoom motors are not activating or limiting. It could be misaligned or slipping gears. Listen for motor running as you press the appropriate function - such as manual focus or zoom. If you hear anything then the motor are running but not adjusting the lens - therefore the gear is loose and/or the motor is slipping. It must be taken apart to repair.
Hitachi... | Answered on Nov 12, 2010
you will need to either use an SD Memory card and transfer it that way or you need to go to hitachi's website or other sites that carry the drivers for mac and download them onto pc, then double-click the downloaded driver file for it to install it into the computer's registry files.
Hitachi... | Answered on Jan 30, 2010
I had a similiar problem and was unable to locate my owner's manual. I called the Hitachi service number at 1-800-448-2244 and they said it was a disk read error. This model can not read DVD-RW. It can only read DVR-R or DVR-Ram.
Thanks for contacting Fixya
Hitachi... | Answered on Jun 29, 2009
I figured it out out of frustration. I used a small flat head screwdriver & gently pryed it open just above the control for turning it on/off. Inside I found that the mini-DVD was shoved in there outside of the mini-DVD sleeve thus causing a perpetual jam. Works OK now as long as my kids don't mess with it!
Hitachi... | Answered on Mar 20, 2009
hi!
i have a camcorder too im using it for some capturing videos on some places. i have webcam for chats and capturing pictures on a computer.so i suggest that use a webcam instead of camcorder. it will be pretty easy to use.
but if you want to use your camcorder as a webcam heres my help. all brand new camcorders have their own cables like usb, adapter, cd drivers, etc.. In interface on your camcorder just plug the usb to your computer. make sure that the computer will detect your camcorder. It will notify you for the installation of your device. If the computer searching for the drivers hardware just insert the cd driver included on the package of your camcorder. install it and when the computer will say that "your device is all ready to use" it means that the computer and your camcorder ready for some capturing moment or can use it as a webcam. i myself is using a yahoo messenger. the best way to apply for some devices like webcams and camcorders. it can easily detected.
i hope that my solutions help you!
thank you for using FixYa as your technical support questions
CHARCOIS
Hitachi... | Answered on Jul 22, 2008
I had the same problem with mine. I contacted Hitachi, and the only solution was to send it to the dealer for repair. I live in Las Vegas and the closest dealer is in Carson, California, so I shipped it. It took about 3 weeks and was quite expensive, but it worked after that. Now I am having the "error code 2881" problem when I try to record with a DVD-RW. According to this website, our camcorder does not support that, it only uses DVR-R or DVR Ram. I am off to the store to buy some, and will let you know if it works.
Good luck Charlie.
Lynda
lyndelgado@hotmail.com
Hitachi... | Answered on Jun 28, 2008
www.dvd-and-media.com/maxell-dvd-r-media.htm
I Have the same problem I searched the net and found this link
hope it works for you look toward the bottom of the page you need the round caddy
Hitachi... | Answered on Apr 14, 2008
Have you tried turning off the auto focus ?
Hitachi... | Answered on Apr 09, 2008
I have the gx5020a camera, and found out that the VRO file is just MPEG2. So copy the VRO file onto your computer from your disc. Once its on your harddrive, you can right click on it and go to properties. Re-name your file from VRO to MPG, making sure that you still have the original VRO file in case you need it for other programs. Once I change it to MPG file name, I can use media player to play it and I have a DVD movie maker where i can edit and record to DVD.
Hitachi... | Answered on Jan 13, 2008
Hitachi DZ-MV350A DVD Camcorder Logo
38 questions posted
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
View Most Popular
DZ Hitachi
  • DZ Hitachi
Most Popular Question
download from hitachi dz mv350a video
  • Video Cameras
