If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
Probably not much you can do it probabily needs a cycle clutch or at least adjusted. If you know how to remove the case you can try spraying with WD40 it may work but it will be temporary.
DickyO
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
It sounds like the cycle shaft is not fully in home position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
The machine is probably gummy. If you know how to remove the case do so, get some WD40 and spray everything that moves espesially the stuff on the outside of the rt. side frame.
Be sure to put WD40 on the escapement (under the platen and paper tray) and the escapement drive mech. (rt. rear of machine) and the correction latching mech (under the rt. dust cover).
